No power at the key
Old Feb 3, 2020 | 11:03 PM
Dan 40's Avatar
Default No power at the key
I've got a Polaris 500 sportsman. It's a 2004. I have power from the starter solenoid to the ECM. From the ECM to the speedometer. Nothing after that. The ECM and speedometer are new. I can't get anything to the ignition switch. There is no power to the junction box either. I'm in serious need of help!!!!
Old Feb 4, 2020 | 02:45 PM
Powerranger262's Avatar
Does the speedometer light up at all?
I'm probably going to say it's the kill switch on the bars, left side.
Old Feb 5, 2020 | 01:47 PM
Dan 40's Avatar
I don't have power going up to the kill switch either.
Old Feb 15, 2020 | 10:21 PM
Polaris kid's Avatar
Default Jump the solenoid
The solenoid could be the problem. Take screwdriver with a wooden or rubber handle and touch the two terminals together. It should spark a little and power everything and it will also start turning the starter. If that doesn’t work then try replacing the solenoid. Hope that’s helps.
Lash3rd
Ask the Editor
May 29, 2020 01:06 AM
bear198
Oct 31, 2014 04:15 PM
seibert77
Oct 26, 2012 10:19 AM
monsterSasquatch
Apr 21, 2011 04:57 PM
Genocite
Jul 31, 2008 01:43 AM
