Honda Rancher
Old Mar 21, 2020 | 10:53 PM
glenfd12's Avatar
Default Honda Rancher
i have a honda rancher 350 es i have replaced the angle sen shift motor and new battery it will shift when you first start to ride after it warms up it stops shifting you can turn it off then turn the key on but dont start it and it will shift but if you start the motor wont even try to shift can anyone tell me whats wrong with it please
Old Mar 22, 2020 | 03:01 AM
At a guess, the regulator overcharging. If your 350 is post 2002 it will show a fault code in Morse, where the gear indicator should be on the digital display, when the fault is on. Either way, check the battery voltage with the engine running. It should not go over 14.5v, much over 15v and the ES computer will shut down.
Old Mar 22, 2020 | 07:00 PM
glenfd12's Avatar
i checked the voltage it is 12 to 13.5 volts so im gussing it is what ever tells when not raced up is going bad do you have any other ideals
Old Mar 23, 2020 | 02:44 AM
Does the digital display show a fault code when it refuses to change? If so what? Only other difference I can think of between engine off and engine on, is the shaking of the motor, possibly a wire vibrating and not connecting properly. Check if you can change gear with the emergency lever when the fault is on, it will be stiff as it has to turn the shift motor via a reduction gearbox, but if it won't change, the fault must be mechanical, though I can't think of anything that would differ between running and not, on the gearchange linkage.
Old Mar 23, 2020 | 05:54 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Also may want to check clutch adjustment and alot of times the reduction gear in front in case needs cleaned and regreased and I have had afew where small bearing in there gets frozen up an stick needs replaced..The early models had a recall on shift linkage cracks or breaks causing shift pattern to be to wide making hard to select gears but only if cant cannot mechanical change an if thats the case will have to remove front case to replace gearshift linkage.just afew more ideals to help.
Old Apr 12, 2020 | 12:02 PM
Rockstargonzalez's Avatar
Default Honda rancher trx420fa2 2014 Oil pump broke what caused it ? (Honda)
(Honda)
I bought a 2014 rancher used and guy told me it was something easy fix . It would start right up but wouldn't move .So a buddy told me to put it on Jacks and see if it would move the tires , so it...
Today 01:33 AM by Rockstargonzalez
Lukas7
Oct 28, 2019 07:11 PM
cstolan266
Jul 16, 2018 11:07 AM
sanders1021
Jun 17, 2008 11:07 PM
warrenwld
Nov 7, 2000 02:01 PM
