2006 Polaris sportsman 800 stalling and won’t idle
Old Apr 2, 2020 | 08:23 PM
Alex Duca's Avatar
Default 2006 Polaris sportsman 800 stalling and won’t idle
Ok so I have been having an issue with my atv and can’t get it to run properly, it stalls and hesitates.
so let me tell you what I’ve done ..
I was getting a code 45 which then I replaced the connecter on the tbap and that went away but the issue is still occurring causing it to stall and sputter and it idles for a little then dies
I’ve changed my coil wires, set the spark plug gap to .035in , cleaned the throttle body , adjusted my tps to the spec .71vdc since I thought maybe it could be that and still same issue. The stop screw is said not to be touched so I just adjusted the tps .. I’m running out of options .. idk if there’s a trick or something I’m missing ..
saint650
Aug 8, 2019 08:12 AM
Redcruiser500AC
May 20, 2011 02:14 AM
weights133
Aug 5, 2010 06:42 PM
uncleshane
Mar 1, 2009 09:32 AM
