2006 Polaris sportsman 800 stalling and won’t idle
Ok so I have been having an issue with my atv and can’t get it to run properly, it stalls and hesitates.
so let me tell you what I’ve done ..
I was getting a code 45 which then I replaced the connecter on the tbap and that went away but the issue is still occurring causing it to stall and sputter and it idles for a little then dies
I’ve changed my coil wires, set the spark plug gap to .035in , cleaned the throttle body , adjusted my tps to the spec .71vdc since I thought maybe it could be that and still same issue. The stop screw is said not to be touched so I just adjusted the tps .. I’m running out of options .. idk if there’s a trick or something I’m missing ..
