03 Sportsman Speedo/starter
I am new here, yesterday my 2003 started up ran down the drive and i looked down and the display was blank. Still running and driving just fine, no digital display or analog speedo. When I turn the key on, no display, no speedo, no start, but i do have lights and power to the 12v plug. It does pull start with the key on, and runs, and turns off with the key. Anyone have any ideas. Thank you
I found the issue, I saw on another forum that someone said said that there was in issue in the engine kill switch/ light/reverse override. I took it apart and did not see anything out of the ordinary. I cleaned it and straightened up the wires and put everything back together and it worked right off the bat. I'm not sure if it was the wires, they were pretty kinked and been in the same position since 2003. Side note: try not to lose the little BB that keeps the light switch tight, or the copper prongs on the kill switch. I hope this helps someone. If it weren't for the other forums like this one I'm not sure I would have found it
