Suzuki LT80 needle valve
Old May 7, 2020 | 10:30 PM
Tony Reed's Avatar
Default Suzuki LT80 needle valve
got an Lt80, had it about 5 years. Kids ride the crap out of it. Here a while back it got to starting real hard, after it started it ran fine. Could ride for as long as you wanted, but once you let off the throttle it would very slowly start bogging down til it would die. It wont start then. I discovered tonight though, if you unscrew the throttle cable out of the top of the carb and lift the needle valve out it'll start and run fine then. Same deal, ride as far as you want but once you stop it'll start bogging til it dies. Just had the carb cleaned by a good mechanic but it didn't seem to help. I see a lot of comments about the petcock too, this machine still has the original one from the factory in it. I believe the machine is a 1987 model. Got new oil and new non ethanol gas in it. Thoughts????
Old May 8, 2020 | 12:46 PM
Lt Granddad's Avatar
You have tried adjusting the idle screw . Will it stay running with the choke on. Also have you checked air filter over the last 5 years. A compression check should also be done.
Old May 9, 2020 | 07:21 AM
LT80's Avatar
LT80 Expert
What he said.
David3307
Oct 28, 2018 12:32 AM
Cmeyers
Aug 31, 2018 07:54 AM
Suzuki_Help!!
Jan 18, 2011 08:38 AM
1966robertsp
Aug 20, 2010 04:21 AM
RobW
Sep 23, 2005 12:21 AM
