Belt hitting crankcase cover at high RPM
Old May 8, 2020 | 08:00 PM
jlmathews1101's Avatar
Default Belt hitting crankcase cover at high RPM
Replaced front clutch and key. The key was sheared off and the rollers were all flat. Replaced all if that and now when hitting high RPM, the belt moves to the top of the drive face and hits the crankcase cover.
Is my rear clutch spring too weak and allowing belt tension to be loose? Don't know what to do from here.
Old May 9, 2020 | 07:19 AM
LT80's Avatar
LT80 Expert
I'm thinking you forgot the big washer in the front clutch. Check a dealers parts fiche to make sure.
Old May 9, 2020 | 09:24 AM
I actually did have it wrong but I looked at the picture and put it back together the right way and it's still has the same problem. The belt is new, only used it for one day of riding.
Old May 9, 2020 | 07:29 PM
LT80's Avatar
LT80 Expert
Something is still not right in there.
Can you post a pic or 2?
whalebus
Nov 22, 2010 08:34 PM
Howmon
Sep 27, 2009 01:12 AM
drumdude
Aug 5, 2007 12:40 PM
Bretman
Jul 20, 2005 08:15 PM
will
Jul 16, 2000 11:54 PM
