Need information on gy6 atv 150cc
Old May 22, 2020 | 08:42 PM
Gy6help's Avatar
Default Need information on gy6 atv 150cc
Old May 25, 2020 | 04:15 AM
No plastics and VIN plate removed, doubt if anyone could recognise it from that, and you have to wonder why the VIN is missing. Though the footwell plastics with all the holes are distinctive, should ensure mud on your boots.
Old May 25, 2020 | 09:40 AM
Gy6help's Avatar
I have the VIN Number i think
Old May 28, 2020 | 03:20 AM
That is the engine number, P57 QMJ confirms it is a 150cc GY6 engine. The VIN plate used to be on that bit between the top front A arms, see the two holes where it was riveted on? GY6 engines were not a very popular choice on ATVs so that narrows it down a bit.
Old May 28, 2020 | 07:54 AM
Gy6help's Avatar
Is there any other way to get The VIN number
Old May 30, 2020 | 02:37 AM
No, and it doesn't always help as some Chinese manufacturers are not listed in the VIN code. Why this need to know who made it?
Old May 30, 2020 | 08:06 AM
Gy6help's Avatar
Im looking for the gear shifter lever and part thats missing from here
Old May 30, 2020 | 08:18 AM
Gy6help's Avatar
What are these
parts
Old May 31, 2020 | 03:33 AM
The thing on top of the box is a breather, just run a pipe upwards to the tank area if you intend going through deep water. The bits you highlight are a splined coupling, we call them muff couplings in the UK, and I guess the other bit is the forward/reverse lever which turns a rod which fits into the muff coupling. My guess would be your gear change doesn't work like that, more likely a lever directly onto the splined shaft and a push/pull rod on the end of it going forwards to the gear change lever.
Old May 31, 2020 | 08:52 AM
Gy6help's Avatar
Is there a kit to fix that part
