Help. 2006 Sportsman 500 dead
Old Jun 6, 2020 | 02:50 PM
aklim's Avatar
Default Help. 2006 Sportsman 500 dead
We were riding on the trail just fine and the wife's machine just died. Will not restart.
When you turn it on, the pump cycles and you see that the display is lit up like normal. Try to crank and nothing. Display goes dark.
Try to crank again and nothing still.
Turn they key off and then go to run position and you hear the pump cycle, display comes on. Try to crank and everything goes dark and no more sound.
Please help. We are camping and can't easily get it back into the RV without power. TIA
Old Jun 6, 2020 | 05:13 PM
Nomicron99's Avatar
Sounds like a bad power connection or ground.
Old Jun 6, 2020 | 05:57 PM
Kymco 450i's Avatar
Shorted battery cell. Disconnect current battery and try jump start without using the current battery.
Old Jun 6, 2020 | 06:13 PM
aklim's Avatar
Battery is good and connected well. I read the post HERE and pulled the battery and swapped with a working one and no joy.
It does start with the pull rope. It also runs.
Old Jun 11, 2020 | 12:03 AM
aklim's Avatar
Switched the starting switch to the other known good one and even an aftermarket one and a Polaris one. All same result. Beginning to think PDM is the issue. Sending it to a tech for an hour of diagnostics to see if anything jumps out at him. I'll try to push him in the right directions if necessary.
Old Jun 11, 2020 | 06:54 PM
Nomicron99's Avatar
Good plan. Electrical problems can be hard to diagnose in person and even harder over the internet.
Old Jun 11, 2020 | 07:19 PM
aklim's Avatar
At this point, I have done what I can to diagnose the problem. Now it would be nice if I could get someone to do the rest of the work.
Also have another ATV with problems. May trade them in for a RZR or Maverick
funguy4649
Oct 28, 2019 11:40 PM
1948boat
Jul 3, 2019 08:59 PM
Granvima
Dec 16, 2007 11:28 AM
heliman28
Feb 24, 2006 04:15 AM
