Chain Loose in FWD Gear
Old Jun 16, 2020 | 08:22 PM
aasghar's Avatar
Unhappy Chain Loose in FWD Gear
Got a new 420 Chain on my 125cc Auto Transmission Daymak. In neutral all good. In Forward Gear the Bottom of the Chain is Floppy, Still drives though. Chain tension in Reverse seem fine.
Any thoughts ? Thanks
Old Jun 17, 2020 | 02:01 AM
Did you check the 420 chain is right for your machine? It won't sit right on the sprockets if it isn't. The "floppyness" will be transferred to the top chain when in reverse. If it isn't, either the rear axle or engine is loose, or a bearing has gone, most likely in the rear axle. On most chain drive quads the chain is adjustable by sliding the rear axle assembly backwards and forwards in the swinging arm.
Old Jun 17, 2020 | 08:38 AM
aasghar's Avatar
It is the right size chain. I'll check the rear Axle today, no reason for it to be loose, the ATV was running fine, until new chain.
Reverse and Neutral seem taut enough, Forward is Floppy at the bottom.
When i installed the chain, i kept pushed the Axle all teh way front, and adjusted back a little for tightness once chain was on.
Thx
Old Jun 19, 2020 | 08:30 AM
aasghar's Avatar
Update: I loosened the 4 bolts at the back, put ATV in FWD, Adjusted to push rear end forward, and torqued the 4 bolts as much as i could.
It's not perfect, but much better.
Thanks @merryman
dwanchena
Jul 1, 2013 03:45 PM
jetmotoracer
May 11, 2007 10:31 AM
stevebuick23
Dec 8, 2004 10:30 AM
blue250r
Dunes and Dune Machines
Apr 15, 2004 06:09 PM
