I'm new here but have a question
Old Aug 1, 2020 | 09:15 PM
Jim Clayton's Avatar
Default I'm new here but have a question
Hello my name is Jim and I bought a Taotao 110 and have done a lot of work to it. My question is, why won't the starter spin when I hit the button? I bought a new battery (it reads 13.12 on the multi), new starter, new handle bar switch, new key switch, new wire harness, but when I put the battery charger on it it starts. Can someone help please?
Old Aug 2, 2020 | 01:58 AM
If you are putting the charger onto the battery, either the battery is flat or a dud, despite the reading, or the battery terminals are not making a good contact.
Old Aug 2, 2020 | 06:19 AM
Thank you merryman, I tried cleaning the posts with sandpaper, hooked it back up and nothing. Another thing, when I turn the key on the tail light comes on, when I hit the start button it goes out, when I release it comes back on.
Old Aug 3, 2020 | 02:09 AM
See what happens to the voltage across the battery when you press the start button, if it drops much below 10v it is either flat or a dud. Other posibilities are bad connections at earth points or on main positive wires, but that shouldn't be affected by whether or not the charger is on.
Old Aug 4, 2020 | 03:52 AM
Default Solved
Thank you marryman,
It was the battery. The place I bought the battery sold me one that wasn't the right size. I also went through all connections and checked my ground. I added some lights. It looks pretty good I think. I'm not sure if we can post pictures but If I get the green light on it I will. Thank you again marryman, you were a big help.
dallaslewis
Apr 20, 2015 05:43 PM
Jwthv00
Oct 31, 2006 11:24 PM
Hinch
Sep 26, 2004 06:13 PM
dadsworry
Sep 6, 2004 12:37 AM
liteweb
Jan 21, 2004 03:14 AM
