2013 Foreman 500 es 4x4
Old Aug 19, 2020 | 09:45 PM
KGuidry's Avatar
Default 2013 Foreman 500 es 4x4
I have a 2013 Foreman 500ES 4x4. Today I backed it out of the drive stopped then pressed the gear shifter to go into first and nothing. The "N" is blinking 2 or 3 times so I know its some kind of code. Any help on this.
Thanks
Old Aug 20, 2020 | 02:39 AM
I assume you have tried switching off, waiting a few min then switching on again? Check if you can change using the emergency shifter, if you can't, the fault is mechanical, with the mechanism in the clutch housing. If you can shift manually, blinking 3 times is Morse code for angle sensor problem on most ES Hondas, but be sure it is 3 blinks, pause then 3 blinks, before going to the expense of a new sensor. Also, a slowing shift motor can throw the same fault, so you could try dismantling the motor and checking for oil contamination and worn brushes first.
Jackief30
Jul 21, 2008 01:24 AM
Derag2
Aug 18, 2005 11:50 AM
lourenco
Feb 10, 2005 02:10 PM
saskman
Oct 30, 2001 05:29 PM
