Failed solenoid on Warn winch
Old Apr 29, 2001 | 11:19 PM
Expeditioneer's Avatar
The solenoid has failed on my Polaris mounted Warn winch. I've only used this winch once, and am a little unhappy with the failure. The dealer mounted the solenoid behind the battery, which is
inside the left rear wheel, and the solenoid is subjected to all the water and mud thrown up by that wheel. Is this a recommended location, or is the solenoid supposed to be mounted in a dry area?
The solenoid is activated by the ignition switch, so it is "on" all the time the ignition is "on". I'm tempted to put in an "on/off" switch in series, so the solenoid would only be activated by that switch.
I also would like to know if there is another, more reliable (cheaper would be nice, too) solenoid that would work. Anyone tried substituting? I'd welcome your ideas. TIA
Old Apr 30, 2001 | 07:01 AM
robh's Avatar
I just saw a brand new magnium yesterday with a dealer installed Warn 2000# winch with a on off switch installed on it. Also his solenoid was mounted under his seat. I would take it back to the dealer and have them get you another one and also have them move it to another place. Myself I didnt install thes solenoid on my quad, cause i think there are times that i will use it and i dont nessasarly need the key on. But I dont recamend that for anyone to do it like i did.
Old May 1, 2001 | 09:41 AM
MWHC's Avatar
oh no! problems with a warn winch again. glad i got a atv superwinch.
Old May 2, 2001 | 08:24 PM
UtahRancherRider's Avatar
I'll bet if you contacted Warn they would replace it. It had to be faulty to start with. I have my solenoid mounted in the rear storage box where it stays dry and clean, but my Father-in-law's is mounted right on the winch mount itself, exposed to all sorts of mud, water, dust, ect... His machine is a 97 Big Bear and he's had zero problems.
Old May 2, 2001 | 08:49 PM
FKNA's Avatar
It was definitely defective to begin with. My solenoid gets submerged all the time and hasn't gone out yet. But then again, I expect it to at any time because those solenoids aren't made to be submerged like that. You can pick up a better solenoid at a high performance auto parts place. Or might even be able to get a marine type from a boating store.
Old May 3, 2001 | 12:27 AM
TEXASCAT's Avatar
i mounted my soly as high as possible and coated the connections with liquid electrical tape. i'm thinking about installing a splash guard to protect it as much as possible without totally enclosing it.
texascat
Old May 3, 2001 | 10:01 AM
4wheelitis's Avatar
I had the dealer put an on/off toggle switch on the side of the top headlght by the 12 volt receptacle. I only turn it on when I need too. This would be easy to install one if you need too.
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
