Ignition help
Old Dec 2, 2020 | 09:28 AM
Lee Lovett's Avatar
Default Ignition help
Help..I have a minerilla 90cc 2 stroke. No ignition on the atv when I purchased it. It does have kickstart on it but I would like to put an ignition on it. Cant not find a wiring schematic for it to save my life. Wires that lead to old ignition are colored as followed. 1 red, 1 black, 1 black w/ white stripe, 1 yellow w/ red stripe, 1 green w/ white stripe and 1 solid blue. Can anyone please help a pal out. My son has been driving me crazy to get it running.
Old Dec 3, 2020 | 03:23 AM
The ignition circuit makes the spark and (usually) is completely independent of the starter circuit, which circuit do you need? Some Minarellis have AC ignition, some a DC one, the circuit for AC is different to DC, and the stator is different, as AC systems have a separate stator coil for powering the spark, as well as the trigger coil, and generator coil(s) for charging the battery.
A lot of Minarelli engines have an electric choke carburettor. If yours has, this will akso need wiring to it.
Old Dec 3, 2020 | 11:33 AM
Lee Lovett's Avatar
yes mine has the electric choke on it, I'm a newbie to this so I cant tell u which circuit I've got but the cdi box is not black like on most ATVs. This one is a blue cube with 5 wires coming out 3 on 1 plug and 2 on the other(safty an kill switches) I believe.
These are the key ignition wires. Cant see in photo but yellow wire has red stripe
Old Dec 5, 2020 | 03:05 AM
Here is the simplest diagram I have for an electric choke AC CDI bike. Your wiring colours may not match this at all, so you need to know which wire does what when wiring the switch and stator wires up, don't just follow the colours on the diagram blind. If your machine is DC ignition, this diagram won't work for it.
File Type: pdf
Daryl Devine
Technical and How-To Articles
Jun 8, 2015 08:59 AM
jplumber
1) Engine problems..
May 10, 2013 06:59 PM
Huber88
Sep 25, 2012 02:08 PM
bovineanimal
Jan 8, 2001 11:01 PM
