Pilot air fuel screw
Old Dec 8, 2020 | 07:45 PM
Smithtismed's Avatar
Default Pilot air fuel screw
New member need some advice 2005 Kawasaki prarie 360 4×4. The pilot screw which is sealed and burried up inside a channel seems difficult to adjust. Does anyone know of an extended screw that sticks out so you can adjust with your fingers, im exausted trying to find the correct one, reputable brand and exact part #. Thanks
Old Dec 9, 2020 | 03:18 AM
The reason it is "sealed and buried up inside a channel" is to stop you messing with it, so don't. If because of an unusual height above sea level, you must, adjust once, then it should be right for the entire time you use it at that elevation.
Old Dec 9, 2020 | 04:21 PM
Thanks for the info merryman, thought it would be beneficial to be able to get at it, Showtime grill set it and forget it. Thanks Tim
atvaddict01
Nov 21, 2004 08:51 PM
hondarider300
Jun 14, 2004 01:35 AM
NLWarrior01
Jun 7, 2004 04:26 PM
yamahawarriormods
Apr 2, 2004 09:30 PM
Domi
Jul 18, 2002 03:10 PM
