fuel mixture screw????????????
Old Jul 16, 2002 | 11:15 PM
Domi's Avatar
Does the fuel mixture screw control 0 to 1/4 throttle? I rejetted to a 180 main, needle on the fifth groove. There's a little hesitation when you punch it. Also is the fuel mixture screw replacable because mine seem's to be semi seized. The slotted screw is getting thrashed.
Old Jul 17, 2002 | 10:46 PM
ScoobyDFW's Avatar
Your pilot jet may be too small. After 2000, Bombardier has gone up in size on the pilot jet. The screw under the carburetor can be richened up to fix the hesitation. I assume the needle is raised all the way?
Old Jul 17, 2002 | 11:08 PM
Domi's Avatar
yea scoob, needles up. I'll find out more ino on the pilot jet. But the air mixture screw is my problem.. you should be able to screw it right out of the carb, should'nt you?
Old Jul 17, 2002 | 11:30 PM
ScoobyDFW's Avatar
I could be wrong, but I think the screw stops before coming out completely.
Old Jul 17, 2002 | 11:35 PM
Domi's Avatar
O K...... So the pilot controls idle to 1/4 throttle. mixture screw is for ..... idle?
Old Jul 17, 2002 | 11:44 PM
ScoobyDFW's Avatar
carb theory
Old Jul 18, 2002 | 12:04 AM
sand45's Avatar
Domi.. did you check your carb diphram ?
Old Jul 18, 2002 | 01:21 AM
Domi's Avatar
Yep. Everything went well. the diaphram has no holes. It runs really well but i've only had a day to fine tune. i'm worried about the mixture screw cause the slotted end of the screw is getting so i cant turn it.
Old Jul 18, 2002 | 03:10 PM
biggerisbetter's Avatar
Scooby,
That is the Best Carburator information I have ever seen. Thanks for sharing!
Biggerisbetter.
cdoren
Aug 16, 2015 11:22 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
