2004 Scrambler 500 electrical problem
I've got 13 + volts comin out of the battery and less than 1 volt comin out of the starter side of a new solenoid when I turn the key. Is there a fusible link on this scrambler ? I'm about to go on a hunt for this short.Service manual says check both sides of circuit breaker. I can't find one. Can anyone help me cut down the hunting time, and offer any tips? Just started pulling the plastic off. Thanks ahead of time. T.J
Haven't Load tested it yet. Why such a dramatic drop in voltage from 1 side of solenoid to the other? Jump started it, it fired up a minute later dash lights and headlights go out and it dies. Turn key off then back on which i assume resets breaker in ECM? Starts again only to do the same.
13.5 v off. 13.12v key on 6.3v key on lights on. If it's the battery wouldn't the charging system keep it running after I jump start it? It would run dash light cuts out and motor dies. Hey thanks for the help
