2004 Scrambler 500 electrical problem
Old Feb 2, 2021 | 06:55 PM
Tj Juchnewich's Avatar
Default 2004 Scrambler 500 electrical problem
I've got 13 + volts comin out of the battery and less than 1 volt comin out of the starter side of a new solenoid when I turn the key. Is there a fusible link on this scrambler ? I'm about to go on a hunt for this short.Service manual says check both sides of circuit breaker. I can't find one. Can anyone help me cut down the hunting time, and offer any tips? Just started pulling the plastic off. Thanks ahead of time. T.J
Old Feb 2, 2021 | 11:43 PM
Yooper265's Avatar
Sounds like a bad battery - have you load tested the battery ?
Old Feb 3, 2021 | 03:23 PM
Haven't Load tested it yet. Why such a dramatic drop in voltage from 1 side of solenoid to the other? Jump started it, it fired up a minute later dash lights and headlights go out and it dies. Turn key off then back on which i assume resets breaker in ECM? Starts again only to do the same.
Old Feb 3, 2021 | 05:02 PM
Yooper265's Avatar
Put a volt meter on the battery and turn the headdlights on , { engine off } does the voltage drop off quickly ?
Old Feb 3, 2021 | 07:07 PM
13.5 v off. 13.12v key on 6.3v key on lights on. If it's the battery wouldn't the charging system keep it running after I jump start it? It would run dash light cuts out and motor dies. Hey thanks for the help
Old Feb 3, 2021 | 07:15 PM
Yooper265's Avatar
Definately the battery , replace it and all will be fine .
Boaters
Sep 17, 2013 10:16 AM
Sladester2
Jun 3, 2013 02:56 PM
JokerCop
Aug 7, 2007 08:37 PM
04scramblerdude
Apr 13, 2004 02:57 PM
robne68
May 3, 2003 08:07 PM
