Help! 97 king quad 300 oil temp light
Old May 20, 2021 | 08:55 AM
Lb28's Avatar
Default Help! 97 king quad 300 oil temp light
Hey I have a 97 king quad 300, after riding it for about an hour easily about 30mph my oil temp light comes on. I’ve already flushed the oil cooler, and it’s seems to be working fine changed oil and filter, level is good oil temp sensor is new. Not sure why it’s overheating it gets plenty of air flow and doesn’t seem to be obstructed flow anywhere. Any one have this problem and a fix ?
Old Jul 28, 2021 | 07:32 PM
NewportHillClimber's Avatar
check and see if your spark plug shows a lean condition when riding around at those speeds where it comes on. if its white on the end check for a lean condition caused by loose spark plug, or carb jetting or sucking air via cracked intake or no air filter
Old Jul 29, 2021 | 09:45 AM
Lb28's Avatar
I have already, it’s not running lean plug is good, not white on the end. Air filter is in great shape no vacuum leaks anywhere so I’m sure that’s not the issue.
Wicked67dart
Oct 3, 2010 02:46 PM
medtech
Sep 24, 2008 10:26 AM
DarkFireDragon
Sep 20, 2004 04:40 PM
atvnut62
Aug 20, 2003 11:22 PM
