1999 lt 80 questions
Old Jun 24, 2021 | 08:24 AM
Zachswigart's Avatar
Default 1999 lt 80 questions
Just purchased an lt 80 for my daughter. I noticed after she rode it for about 10 minutes and shut it off The cooling fan never would shut off. It ran for a good 20 minutes before I finally unhooked the battery. Is this normal?. Also do you have to have a battery to run the quad. I ordered a pull start to do away with the starter.
Old Jun 25, 2021 | 02:22 AM
Jack will probably be on here later and he knows a lot more than me, but the fan is bolted to the flywheel, so stops when the engine stops. Your electric fan must be something a previous owner has fitted to the bike. You don't need a battery to run the LT80 but pull starts are fine when a bike is an "instant starter", not so good if a drop of water gets into the carb or compression is getting down. Keep the electric start and use the pull start as a back up.
Old Jun 27, 2021 | 07:54 AM
LT80's Avatar
LT80 Expert
I agree, the electric fan is a add on, and not needed unless they did something goofy with the air cowling. I'd think there would be a shut off switch somewhere.
FYI: the stock air cowling works fine. Not sure if it's there, but thought I'd mention that.
Old Jun 28, 2021 | 05:18 PM
Ended up putting a top end in a the bike. Had low compression. Putting it back together and noticed a wire that goes to the 2 prong connector on coil is just hanging there. Black/red and a black/white wire. Where does the black/ white wire go
Old Jul 5, 2021 | 07:42 AM
LT80's Avatar
LT80 Expert
I hope you didn't change the cylinder studs you got with that wuhan special. They seem to stretch very easy.
Wire is a ground I think.
42F
May 6, 2005 11:03 AM
RyDog
Apr 18, 2004 10:16 PM
