Throttle Up At Start Display Blanks and Starter Stops
Old Jan 14, 2022 | 07:09 AM
Ruk's Avatar
Ruk
Default Throttle Up At Start Display Blanks and Starter Stops
I have an issue with a Coleman 125 I bought for my son. When starting it up I cannot give it throttle. When I do the starter stops and the display goes blank. Sometimes the display resets as if I had just turned the key into the on position. Once I get it running it's fine but as you can imagine its hard to get it going without the ability to give it throttle especially on a cold day. Any suggestions on how to troubleshoot to the cause of has anyone seen this before?
Old Jan 15, 2022 | 03:03 AM
Probably a loose earth, so the throttle cable is becoming the earth wire. Very dangerous, as it can start to melt, then stick open when you are riding.
Old Jan 15, 2022 | 06:48 PM
Ruk's Avatar
Ruk
I didn't even think about that being the issue. I'll trace the ground down again and check that throttle cable out. Thanks!
Old Jan 19, 2022 | 08:11 PM
Ruk's Avatar
Ruk
Lightbulb
I didn't find anything wrong with the cable. Could the valves need adjustment?
Old Jan 20, 2022 | 03:11 AM
It is the earth wires from battery to frame and engine that need checking. Check the positive from battery too. Valve adjustment won't stop the display going blank, even if it is not an earth problem, you definitely have an electrical one. Could even be battery flat or bad.
Old Jan 20, 2022 | 10:26 AM
Ruk's Avatar
Ruk
I'll dig into it deeper this Saturday. Thanks!
cubano222
Jun 10, 2017 09:46 AM
fowler5084
Feb 10, 2010 01:38 PM
racerx333
Nov 3, 2009 07:09 PM
jwmm04
May 1, 2006 10:32 AM
brandons
Apr 20, 2003 02:36 PM
