Crankshaft Sprocket (Special Nut) Torque Specs
Old Jan 18, 2022 | 09:10 AM
Tazzin's Avatar
Default Crankshaft Sprocket (Special Nut) Torque Specs
Hey guys,
I'm working on getting the timing chain and timing in general set correctly. My issues is when I got down to the crankshaft sprocket (special nut), this is a left hand threaded nut that when I went to check it with my hand, i was able to loosen without much effort at all. I grabbed it with one hand and simple started loosening it. I have checked my service manual but I can't find anything about any torque specs on the 'special crankshaft sprocket nut' in there anywhere. I do remember seeing something on Partszilla video about the guy mentioning that it doesn't have to be 'tight' as the rotation of the engine 'tightens' as it needs due to the reverse threads. Now, I need to know the proper tightening procedure for this. I have attached an image to show the nut in question.. Thanks in advance for any help/information.
Old Jan 18, 2022 | 02:55 PM
Tazzin's Avatar
Hey guys,
I did a different type of search 'slotted nut' and found this in the forum:
https://atvconnection.com/forums/pol...can-i-buy.html
I should be good with this information.. sorry to waste time.. will try to find a way to close this thread.
IL0VELAMP
Oct 9, 2006 06:59 PM
DUFFSTER
Feb 9, 2005 09:28 PM
MedievaL
Nov 20, 2003 12:34 AM
caliraptor
Nov 10, 2003 12:46 AM
caliraptor
Jun 12, 2003 01:32 AM
