Trouble help me
Old Jun 10, 2022 | 01:58 AM
Russ kent's Avatar
Default Trouble help me
My 110cc Chinese quad will only crank and start if I jump the starter and I changed everything but the electric start.
Old Jun 10, 2022 | 02:00 AM
Russ kent's Avatar
My Kawasaki will only start if I jump it from starter too and I just changed the solenoid and the battery.
Old Jun 11, 2022 | 01:57 AM
Starter circuits usually have a lock-out so you can't start them in gear and/or without the brakes on. The most common problem is the start button not connecting properly, next a faulty solenoid, but new owners not knowing to have the bike in neutral with the brakes on is another common problem. To check the solenoid if it is not clicking when you press the button, you get an incandescent 12v test lamp and put it across the two thin wires going to solenoid. Switch on, lock-outs on, press start button and, if lamp lights, you must have a faulty solenoid. If it doesn't, one wire should be pos and the other neg with start button pressed, so test for which has no power to it and trace that one back, to find the fault.
Cameron2012
1) Engine problems..
Aug 12, 2021 01:59 AM
Dame0927
Oct 29, 2015 10:13 PM
66dave80
May 23, 2012 12:11 AM
