90cc Loncin dies after few seconds
Old Aug 13, 2022 | 12:55 PM
Cfox10's Avatar
Default 90cc Loncin dies after few seconds
I picked up a Loncin 90cc (NST Branded) for my daughter and trying to get it up and running.
  • New carb w/ factory main jet (tried multiple carbs on hand and all reproduce the same issue. Including known working carbs)
  • Adjusted valves
  • Has a new wiring harness + cdi + ignition switch + starter relay + kill/start switch
Had to add a new wiring harness as the original was toast.
Got it running initially and went to ride it with myself and daughter on it - not even considering the fact that the tires were completely flat. So it struggled for the 5 ft it drove and then stalled out on us.
Since it stalled out I can't get it to run any longer than a few seconds.
It makes a long hissing / slow release from the exhaust. This takes quite a while and unlike any air exiting an exhaust that I've heard.
At a loss right now.
Old Aug 13, 2022 | 06:20 PM
Cfox10's Avatar
Ended up being a clogged up exhaust.
Pulled it off and it fired right up.
Blew it out with air compressor and now air flows freely. Bolted back up and fires right up.
Cfox10
Aug 13, 2022 12:48 AM
MSG67
Mar 28, 2018 06:35 AM
Sofa
Nov 10, 2016 12:38 PM
UBETRUN
Mar 27, 2004 02:09 PM
