scrambler pvt belt
Old May 3, 2001 | 03:40 PM
josam's Avatar
has anyone ever "tore up" the pvt belt on their scrambler? i have a 500 scrambler and would love to use it for some misc. small jobs around the house (pull small utility trailer, light snow plowing, pulling the kids on their sleds...) but was told by the dealer that without the low gear i would "tear up the belt". i use to pull the kids on their sleds with my old 400 scrambler and even pulled the utility trailer a few times before i knew any better and never had a belt problem. none of the people i ride with have ever had a belt problem. i understand that the low gear is critical for serious hard work but for light work...? has anyone ever experienced any such problem or is this just more overkill like the multitude of safety stickers pasted all over the machine?
Old May 3, 2001 | 10:52 PM
scr500's Avatar
I pull people stuck in mud out occasionly...no problems.BTW,mine is a 2001 and they have lifetime guarantee on the belt against breakage.
Old May 4, 2001 | 07:39 AM
maxdad's Avatar
I have towed several quads that would not start around to start them and pulled a suzuki 250 quadracer thru a ditch about 12 to 15 feet high on each side with no prob or damage to the belt.
2000 scram 400 4x4
Old May 4, 2001 | 06:45 PM
Farmr123's Avatar
The belt WILL last longer for slow speed high load use. The difference will not be that great as long as you adhere to one rule. Do NOT hold the throttle open for more than a second or two without having the wheels spin. For example, if you are towing someone out, and hit the gas, and the wheels are not spinning, you are going to overheat the spot on the belt where the pulley is trying to grab. If the wheels are spinning, you are spreading the load over the entire length of the belt. Doing what I described above can put a flat spot on the belt, after which its life is pretty short.
Old May 4, 2001 | 08:39 PM
Englishmatt's Avatar
Go out and buy a goodyear power streak belt and you should have no problems. I have a 2000 500 scrambler and tore up the belt because of bigger tires and a white spring.I put the power streak in a few months ago and no problems since.
Hope this helps you.
Matt
2000 500 Scrambler.
Old May 6, 2001 | 05:07 PM
jpstercj7's Avatar
I have a 2000 sc 500 4x4 and have went though 3 belts, and fixing to have to get another.And i don't even pull on no body or any thing.Who sells them goodyear belts b/c i think that is what i need.
Old May 6, 2001 | 10:57 PM
xcr660's Avatar
hey englishmatt i see you said you put bigger tires on your sc is 4x4 and did you put bigger on all four ? your input on this would be great because would like to do this but rear only if possible
Jeff Roper
Feb 1, 2022 11:48 AM
exmotocrosser
Sep 13, 2019 06:12 AM
buddieboy
Dec 9, 2016 05:50 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
