Why Won't This Engine Run?
Old Apr 8, 2023 | 06:55 PM
djshad1469's Avatar
Default Why Won't This Engine Run?
I picked up a 110cc quad. Compression tested at 160psi. Had spark and fuel, but couldn't get it running. Checked timing marks and adjusted valves. Still no run and made a banging noise when turning over. Removed it and pulled head to be sure piston was at TDC and timing marks all lined up. Yup. Pulled right side cover thinking something broke inside, but no metal fragments. Bolted it back into a bare frame with no exhaust. Wired it up and ran fuel. Fired right up and ran great. Then I hooked up the exhaust and the banging was back and it won't run. This is not the same exhaust as before, so it has to be the engine. What can be wrong?
Old Apr 8, 2023 | 08:48 PM
nny's Avatar
nny
Sounds like it has a blocked exhaust pipe check to make sure theres no blockages.
Old Apr 9, 2023 | 05:27 AM
djshad1469's Avatar
If I was using the same exhaust I would agree, but it was a different one. I also put a different engine in the quad that this engine came in and it ran fine with that exhaust. I think it has to be an engine issue.
Old Apr 9, 2023 | 05:22 PM
papa hogg scoot's Avatar
Loved
Community Favorite
I know this is an dumb Ideal but put new NGK spark plug in it
Old Apr 9, 2023 | 05:23 PM
Loved
Community Favorite
What about the air system? air box? air filter?
Old Apr 9, 2023 | 07:58 PM
djshad1469's Avatar
I'll try a new NGK plug. There was no air filter/air box on there.
Old Apr 10, 2023 | 06:08 PM
Loved
Community Favorite
Got to have aif filter or air box assembly for mixture to be correct unless carb is jetted to run without
Old Apr 10, 2023 | 08:12 PM
djshad1469's Avatar
Apparently this wasn't a dumb idea at all! I put in a new NGK plug and now it runs with the exhaust on! Never would have guessed replacing a working plug would make a difference, but it did. Thanks to Papa hogg scoot.
Old Apr 17, 2023 | 03:50 PM
GilbertMacklin's Avatar
Thanks for the suggestion Papa hogg scoot. I am also facing the same issue and you made my day
Spoiler
djshad1469
Aug 23, 2021 03:24 AM
sanchezjesusisawesome@gmail.com
Apr 10, 2020 11:19 PM
djblade17
ATC 3-Wheelers
Jun 17, 2009 09:03 AM
go-hard-or-go-home
Feb 15, 2008 11:45 PM
waterboyken
Sep 15, 2007 08:31 PM
