LT230s just purchased
hey guys i just picked up what i think is an 85 lt230s, how do identify year?
FRAME# JSAAJ43AXF2108159
ENGINE# J411-108029
bike runs, smokes a little at start up, do you guys use the decomp lever?
i just received left side cover OEM(it was cracked and oil is leaking out), waiting for sprocket cover(should be delivered in a day or so)
i'm missing the entire rear brake assembly, tank, master cylinder, hose to rear (rear caliper is still on bike)
there is this great site vinces cycle and machine shop with tons of parts and upgrades but its shut down, are there any other sites i can check out?
i wanted to buy the following from vince's site
front wheel bearing seal combo
rear axle bearing seal combo
upper ball joint
lower ball joint
aluminum carrier
swing arm bearing seal kit
rear caliper repair kit
block off plate
front master cyl rebuild
rear master cyl rebuild
upper roller
swing arm roller
lower roller
steering wheel shaft bushing
complete front and rear bushing kit
foot shifter linkage repair kit
inline fuel filter
repair/service manual
spark plug
ill probably powder coat the frame at some point
front and rear stiffer suspension
all new plastics
thanks
ENGINE# J411-108029
upper ball joint
lower ball joint
aluminum carrier
block off plate
upper roller
swing arm roller
lower roller
inline fuel filter
spark plug
all new plastics
thanks
You need to find someone breaking a 230s for the missing bits. Regarding the "consumable parts" it needs, there are aftermarket parts makers like Bronco, All ***** and Arrowhead. Their spares are sold through a generic parts supply system, separate from Suzuki's own parts system, to local ATV repair shops. So most dealers & repair shops should be able to get all available aftermarket parts for the 230s. Here in the UK there are one or two dealers who have an on-line shop as well, I guess there will be many more in the US, some will have shops on eBay.
With some bikes, you get a new O ring included with the filter. However, if you don't:-
https://www.suzukipartshouse.com/oem...59e2f/oil-pump
The following users liked this post:
NYmike (06-16-2023)
TacticalRedneckofKentucky
Help With Forum Software!
05-05-2012 02:07 PM
