LT500 stuck in gear and will not shift need help
Old Jul 16, 2023 | 02:46 PM
Davidfleming's Avatar
Default LT500 stuck in gear and will not shift need help
I need some help I can not figure out why my 500 is stuck in a gear and won’t come out or go in a new gear. This happened after I put a new piston in and checked everything on the bottom end. Everything look good not a hole lot of play. I have adjusted the clutch and it’s still stuck in gear and will not shift.
Old Jul 17, 2023 | 02:17 AM
Probably a selector problem, are you sure you put everything back together properly when you "checked everything on the bottom end" You are going to have to take the cover off and check that selector mechanism anyway.
Slee
1) Engine problems..
Sep 29, 2022 02:17 AM
rjsessions008@icloud.com
Sep 19, 2022 01:40 AM
threeeleven24
Jun 11, 2009 11:31 AM
kherman123
Jan 15, 2006 12:58 PM
Spandexgranny
Mar 17, 2003 09:36 PM
