Sportsman Carb Leak
Old Dec 15, 2023 | 06:41 PM
chuter's Avatar
Default Sportsman Carb Leak
I have a carburetor leak on my 2008 Polaris Sportsman 500. After looking at the carb, I found that the vent tube, which is attached to a nipple on the bottom of the float bowl, is missing. Does anyone know of a replacement, or the size of the tube neccessary to replace it. How long is the tube and how is it routed. Will replacing the tube stop my fuel leak, or do I need to dig into the carb?
Old Dec 17, 2023 | 04:10 AM
Many bikes have the tube missing. It stops fuel dripping onto the hot engine/gearbox cases, personally I wouldn't bother about it. However the leak is caused by the float needle sticking and needs fixing. It may just be a bit of grit between needle and seat. Easy fix is to turn fuel tap off, run engine until it stalls from fuel starvation, turn tap on, and the rush of fuel past a wide open float needle may shift the dirt. If this doesn't work you need to remove and clean the needle and seat, checking the tiny plunger in the needle is springing out.
Old Dec 17, 2023 | 07:41 AM
chuter's Avatar
Thanks merryman. That is what I was expecting, but needed clarification. Have a good one.
bgonzo
Oct 11, 2022 04:21 PM
Mcdougaldm
Aug 23, 2013 06:32 PM
Ragelite
Aug 4, 2009 06:19 AM
AC400TX
Dec 8, 2008 02:16 AM
bjamin
Nov 16, 2004 11:49 PM
