1994 Suzuki lt-f 250
It will fit on the rim OK. You will of course need the same 25" outside dia on both sides. I'm not familiar with that model but if 4wd the front tyres would also need to be 25 outside dia if you fit 25" rear ones and, as the 25 x 12 x 10 are wider and taller, they may foul on the plastics or exhaust, especially when you go over a bump, so check how much clearance those 24s have now, before going wider, and bigger on outside diameter.
