Dinli DL601 50cc WALBRO WJ98 carburator HELP
Old Mar 31, 2024 | 10:08 AM
gouna's Avatar
Default Dinli DL601 50cc WALBRO WJ98 carburator HELP
Hi,
Excuse me, I'm French.
I found a DINLI DL601 50cc Quad in a barn.
The carburetor hoses were disconnected and/or missing, and I cannot find any assembly diagram for the WALBRO WJ98 carburetor...
On the carburetor there are 3 connections, a fuel inlet, an oil inlet, and a 3rd location (this one gives me a problem, I can't find any correspondence or connection for a hose... is it simply a venting ?)
Thank you so much !
Old Apr 1, 2024 | 02:46 AM
Diaphragm pump carbs continually pump fuel from the tank, any excess that is not used by the jets, is pumped back into the tank, so you need a pickup pipe from the bottom of the tank and a return pipe to near the top of the tank. An oil pipe on a diaphragm pump carb is unusual, but some two stroke engines pump oil into the carb or manifold, rather than using pre-mixed fuel in the fuel tank.
Old Apr 1, 2024 | 10:54 AM
gouna's Avatar
Thanks, I'll go see if I can find an entry on the tank
Christian55200
Nov 28, 2022 03:07 AM
AntonioE
Apr 14, 2022 05:25 PM
vbosch55
Mar 20, 2018 08:09 AM
Tom Shonka
1) Engine problems..
Jan 20, 2012 11:01 AM
Tom Shonka
Nov 24, 2010 08:35 PM
