2005 MV7 no spark at all
Old Sep 18, 2024 | 07:29 PM
Ninja_nic's Avatar
Default 2005 MV7 no spark at all
Hello this is my first post here. But I have an 05 MV7 (sportsman 700 really) in the shop at the moment that has absolutely no spark what so ever. Now this is a carb model with the Kokusan ignition system. I have gone through the entire ignition system at least 5 time using the service manuals flow chart and resistance measurements. Everything tests out just fine. So I replaced the CDI with a cheap one cause customer didn’t want to spend $600 on one. But still no voltage from CDI to coil. Now I tested the kill switch again, works as it should. And disconnected from CDI to rule it out. Then I tested the ECT again and disconnected it as well. I have triple checked my grounds and powers coming out of CDI and regulator. I have cleaned frame and batt grounds. I tested the ignition switch it’s fine, I even unplugged the instrument cluster to see if that had any effect( it doesn’t come on at all anyways). What am I missing? I need some help cause this is getting to be a non money making job and I need it gone!
Could the lack of a functional instrument cluster cause it to not spark? I kinda doubt it but I’m starting to question everything. Please help me!
badsanta010
Oct 22, 2016 01:43 PM
Davidxfields
ATC 3-Wheelers
Nov 8, 2012 04:17 AM
jonnny
Mar 29, 2009 05:20 AM
upssmann
Jan 25, 2005 08:49 PM
pimp250r
Oct 8, 2004 11:48 PM
