Main Fuse Blowing when Starter Button Engaged
Old Oct 14, 2024 | 11:26 AM
JBaird's Avatar
Default Main Fuse Blowing when Starter Button Engaged
Main 20amp fuse flows when I hit starter button. With Ignition switch on everything seems normal - dashboard lights/lights work etc.
Attached wiring diagram. Seems to be a fuse between starter button and common to CDI - it is ok. Does that mean issue is with the hot side thru the Starter/Aux starter relay.
Could it be either a bad Starter relay or the Aux starter relay? Or the wiring? The CDI seems ok - but it doesn't get the juice as the fuse blows.
Any help would be appreciated!
File Type: docx
Old Oct 15, 2024 | 03:13 AM
That is one weird wiring set up. Normally a thick red goes direct from battery to main solenoid, not going through fuse or ignition switch as shown on the diagram. I would check the starter motor is OK and, if it is, feed the wire, top one on the drawing, direct from main solenoid to battery pos post, by-passing the ign, switch and main fuse. Then see what happens when you press the starter button.
warriorking97
Jun 4, 2009 05:53 PM
400L2X4
Mar 18, 2005 10:47 PM
kanz24
Oct 12, 2003 07:00 PM
BUDXXX
Aug 28, 2003 01:52 PM
lively
Jun 12, 2003 12:06 AM
