2005 artic cat 400 4x4 auto
i have been getting after market carbs for this machine and they just keep causing problems. leaking fuel or not starting in the cold. can anyone recommend a better carb that will work ? maybe one with a manual choke? ive been looking around but i cant find much
Can't say for certain, but Arctic Cat were using Suzuki engines about then. Worth comparing an Eiger engine to yours (exploded views in on-line parts books from partzilla etc.) Eigers had a manual choke carb, however they also had a vacuum operated fuel tap, so didn't fit an overflow drain from the float bowl, if it does overflow due to a faulty float needle, with no vac tap to stop the flow, it fills engine and air box with fuel.
