2005 artic cat 400 4x4 auto
Old Dec 4, 2024 | 03:52 PM
Kenshinzx's Avatar
Default 2005 artic cat 400 4x4 auto
i have been getting after market carbs for this machine and they just keep causing problems. leaking fuel or not starting in the cold. can anyone recommend a better carb that will work ? maybe one with a manual choke? ive been looking around but i cant find much
Old Dec 6, 2024 | 03:41 AM
Can't say for certain, but Arctic Cat were using Suzuki engines about then. Worth comparing an Eiger engine to yours (exploded views in on-line parts books from partzilla etc.) Eigers had a manual choke carb, however they also had a vacuum operated fuel tap, so didn't fit an overflow drain from the float bowl, if it does overflow due to a faulty float needle, with no vac tap to stop the flow, it fills engine and air box with fuel.
Old May 29, 2025 | 01:55 PM
seriong_hoo's Avatar
Mikuni VM Series has an excellent reputation for small to medium displacement engines (100–600cc). Easy to tune, very stable.
richolley
Nov 22, 2011 12:00 AM
nx95240
Jul 23, 2009 06:59 PM
v2rider
Aug 5, 2006 07:18 PM
Maule180C
Apr 15, 2005 01:11 AM
