Jetmoto 200cc air cooled
How’s it going new to the forum and I have a few questions about the 200cc Chinese engines . Mine is having issues after my clutch cable snapped . At first I thought it was only the cable that snapped but after inspecting it I noticed the clutch lever had a lot of play it was loose , so I took it apart and it seems like the shift lever is also loose and clutch seems like it’s engaged . Has anyone had similar problem .
Water cooled helps keep the engine from overheating and will result in a bike that lasts longer (typically). This allows engines to perform better overall and will allow a maker to design the engine to run better but hotter, expecting the liquid cooling to help mitigate the heat.
