2001 Prairie 400 4X4 runs rough under a load
Old Feb 27, 2025 | 03:22 PM
jrclen's Avatar
Default 2001 Prairie 400 4X4 runs rough under a load
I changed the plug, gapped it, and changed the air filter. When I open the throttle to speed up or go up a hill the machine runs rough, missing bad. Starts right up choke works fine. Ideas?m
Old Feb 28, 2025 | 02:46 AM
Clean the carb out, remove float bowl, remove jets, blow through them, and the holes they came from, out with compressed air, check float bowl for dirt and water, replace and see if that has fixed things.
Old Feb 28, 2025 | 08:44 AM
jrclen's Avatar
Thanks Merryman, I'll give that a try.
Mike27856
Aug 4, 2007 08:43 PM
BK
Nov 18, 2003 04:41 PM
dhigley
Mar 22, 2000 08:40 PM
