2001 Prairie 400 4X4 runs rough under a load
I changed the plug, gapped it, and changed the air filter. When I open the throttle to speed up or go up a hill the machine runs rough, missing bad. Starts right up choke works fine. Ideas?m
Clean the carb out, remove float bowl, remove jets, blow through them, and the holes they came from, out with compressed air, check float bowl for dirt and water, replace and see if that has fixed things.
