99 SP500 sqeaks
Old Nov 18, 1999 | 11:23 PM
Aniel's Avatar
I have exactly the same quad and exactly the same problem. If you grab the front end (rack/bumber) and start shaking it pretty rough you will notice that the tubes connecting the front end to the chassis squeal when moved. The only solution I see to this is to insert a rubber bandage around the tubing fitting inside the chassis, furthermore preventing friction between metal. I might be wrong in the location of your rattle, but this had me worried also, however I just left mine alone, considering that a lot of rubbing would need to take place before the metal wears out!
Aug 21, 2015 01:46 AM
FireFighter
Jan 7, 2001 04:50 PM
bobvan
Sep 10, 2000 01:36 PM
alaskaweasel
Aug 24, 2000 08:49 AM
cstark
Sep 11, 1999 01:21 AM
