99 Xplorer 400 Recoil Water Drain
Old May 15, 2001 | 03:36 PM
jerrysonoma's Avatar
I was riding last saturday and just noticed that some water got in there and a little mud. What should I all due to drain it, i was looking for a bolt on the bottom to drain it but couldn't find it, i noticed there was a bunch of bolts going around the recoil case holding it on, should i just take off the bolts? or is there a easier way? also should i spray some water in there to get the mud out, kinda sticky. Also, is the drain bolt on the circler part more or the square part the recoil case is connected to. Also is it necessary to take off the skid plates to get to drain? thanks for the help.
Old May 15, 2001 | 11:43 PM
Anybody have a guess?
Old May 16, 2001 | 01:01 AM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
There should be a bolt at the bottom of the case. It is one of the bigger ones facing straight down. My reference is my '96 SP400, so it should be similar. You will have to take off the skid plate on the bottom to get at it. While you are there, pull the other drain plugs like the starter plug, etc. You may want to call your dealer also for more info, that's how I found out.
BTW, if you got it wet pretty good, it will take awhile to dry out. When you pull the drain plug out, pull the recoil over a couple times and let it dry good. Repeat that until it is dry. I put the plug back in mine before and pulled it many times after and water still came out. It takes a bit of time. Not sure about the mud, but hopefully it's not much. If you don't get it dry, it will freeze up in the winter.
Hope this helps.
Old Apr 25, 2003 | 07:38 PM
paulywally's Avatar
Default 99 Xplorer 400 Recoil Water Drain
Take the skid plate off and it is a large bolt on the bottom of the starter housing next to the recoil starter housing
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
wrencher82
Sep 30, 2015 04:27 AM
rockinkgin
Sep 25, 2015 01:52 PM
