stock carb problems in ds
Old May 19, 2001 | 04:56 PM
dsbomb's Avatar
hey everyone, my ds spits back through the carb when you touch the throttle lightly. it has done it since new. its about a year old. you sit idling and push the throttle a little bit and hold it and it will spit back .sometimes it will kill the motor when you start to take off. any help appreciated
Old May 19, 2001 | 10:03 PM
ScoobyDFW's Avatar
Have you tried adjusting the pilot fuel screw under the carb?
Old May 21, 2001 | 09:56 AM
dskurt's Avatar
Mine does that when its warm. My pilot screw is at 2 and a half turns. Which way would you suggest going with it?
Old May 21, 2001 | 07:08 PM
dsbomb's Avatar
ive turned the screw in and out at different adjustments and it doesnt help the spitting. i have a dynojet needle and jet in it but i dont think it would make any difference
Old May 23, 2001 | 04:59 PM
Joseph's Avatar
I just went thru that issue with mine. I even took mine to an authorized dealer who jetted the bike and adjusted the carb but did not fix the problem.
The problem is a loose wire on the ignition coil.
The ignition coil is mounted uder the tank and the wire can been seen from the left side slightly above the rev limiter. It is a black wire and the bike will start once off but tends to act up when lightly pressing the throttle.
I discovered this while installing an RPM gauge on the bike. The coils needs to be tapped in on the installation at which time I discovered the loose wire.
If you cant find the wire contact RON WOODS and ask them to fax you a copy of the installation sheet for the RPM Gauge and you will find it.
Good Luck,
Joseph Oceguera
E-mail Joemiami07@aol.com
00 DS 650
Custom X Muffler
Rotax Box
K& N Filter
Carb. Jetting
Alba Racing Kit
Nurf Bars
RPM Undercarrige Protection
6 Pack Rack
Ron woods RPM Gauge
Old May 23, 2001 | 08:28 PM
JSsDS's Avatar
Excelent info Joseph, this is the kind of feed-back that makes this forum so good.
DSBOMB; If that doesn't fix it though, check the valve clearence if you havn't already done so.
Old May 23, 2001 | 11:30 PM
dsbomb's Avatar
THANKS FOR THE INFO GUYS, I'LL TRY THAT COIL WIRE WHEN I GET A CHANCE. THEN MAYBE THE CLEARANCE. I'LL LET YOU KNOW WHATS UP
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
