Attention H.O owners! Carb vent line question.
Old May 19, 2001 | 07:30 PM
Odin's Avatar
I have a 2001 HO Sportsman. Yesterday I was changing the main jet and noticed I had only one vent line on the carburator? What...? I looked at my service manual and it shows TWO vent lines with a tee going to the frame.
I checked the picture in the book and compared it to my quad and the carburators are different? WTF...?
I then checked my dads 2000 1/2 Magnum 500 he has two vent lines coming from the rear of the carburator to the frame like the picture in the service manual.
My quad has a vent line on the right hand side of the back of the carburator and a black cap on the left... with NO TEE ?
Question is this: Are your HO's the same as mine, and did Polaris screw up and just show a picture of a 34mm carb instead of a 40mm carb in the service manual?
Next question I have is what will happen if I put a tee in myself and route it like the factory picture in the service manual? These breather tubes help float bowl pressure in the carb.
I will be calling my dealer on monday to find out more on this new situation.
Old May 19, 2001 | 08:11 PM
Dazed's Avatar
Mine is the same as yours So relaxe It is ok Plus your dealer will Have no Clue As that is what they are for. They will tell you bring it in and we will look at it. So Don,t worry It is just fine.
Old May 19, 2001 | 08:36 PM
Odin's Avatar
Kewl! I hate it when they make mistakes in the Polaris BIBLE like that... it's not right... to scare the owner of the quad like like that.
Muddin ain't easy... Da "Ho Train..."
Old May 20, 2001 | 12:01 PM
DieselPro's Avatar
Odin,
Just for curiosity, what jets do/did you have? We are in similar elevations.
What other mods are done?
Old May 20, 2001 | 02:11 PM
Odin's Avatar
I am running the K&N filter right now.
I just changed my winter jetting from 157.5 back to stock 152.5 with the 157.5 in warm weather was just too much. I pulled the plug and it was very dark. Now for winter riding the 157.5 is awesome.
I was thinking of running a 155 jet this summer that is one step larger than stock.
When I have more time I am going to supertune my HO. But to do this requires splitting the recoil case to check and see how far the timing is advancing.
I am also going to try that carburator vent line tee mentioned in the above post.
Other than that I have a Polaris cargo box "The black box that rocks", hand guards, heated grips, mirror, fuel pack, custom latches, trailer ball with tow hook ring in rear, tow hook in front, custom tow strap hooks on back of cargo box.
BTW I had my Victory on a Dyno Jet 250 dyno for a HP run did 68 HP at the rear wheel. Pretty strong for a 99 Vic.
There was a 117 cu in harley TC88 there that did 127HP they had two guys sitting on it because he was spinning the drum too fast.
Jmuddin284
Jan 19, 2026 07:16 AM
rcappie4
Jul 10, 2015 04:54 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
