Clutch Adjustment
Old May 21, 2001 | 12:49 AM
Max's Avatar
Max
Has anyone ever adjusted their wet clutch on a manual shift model? Underneath an inpesction plate on the right side of the motor is 2 adjustments with jam nuts. How do these work?
I have a '99 400 with about 1400 miles. It is not exhibiting any problems, but i was wondering if this should be done.
Thanks
Max
Old May 21, 2001 | 02:54 AM
BONER's Avatar
OK, when you get the cover off, you gotta lossen the jamb nuts on the 2 screws under the cover. Then rotate the adjustment screw that is farthest forward counterlock wise (lefty lossy) untill it stops. Now, rotate the 2nd screw (farthest to the rear) back and forth to make sure it moves freely, then lock the jamb nut on it. Now rotate the screw that is farthest forward 1/8 of a turn clockwise (righty tightly) and then lock the jamb nut. Test it out, then install your plate.
BONER's Avatar
I forgot to ask this, but how did you get your access plate off?? Just a normal screw driver or what?
Old May 21, 2001 | 09:54 PM
t02ks's Avatar
you may have to use an impact driver (hammer type) to loosen the screws
Old May 21, 2001 | 10:32 PM
BONER's Avatar
I konw the manual says that, but I want to know if he had to use it.
Old May 21, 2001 | 11:29 PM
Max's Avatar
Max
Boner, I guess I must have gotten lucky!..I have a very large Craftsman phillips srewdriver that I used to think, "what in the h#@$ will I ever use this for?", until now. I just used the screwdriver and good old German temper and they both came loose. Thanks for the advice.
PS how will I know if this adjustment was sucessful?
Thankfully,
Max
Old May 22, 2001 | 12:14 AM
BONER's Avatar
Well, if you shift it and like it, it was sucessful. If you don't like it, you will have to play with it till you like it.
ghost civic
Jan 15, 2020 07:43 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
