Tire sizes
Old May 30, 2001 | 03:52 PM
QuadDude05's Avatar
Currently i have 22x11.00-8 (thats what it says on the sidewall) tires on my universal rims. i want to get smaller tires for more speed but not sure what size to get and still be able to keep them on the rims, anyhelp?
Old May 30, 2001 | 06:30 PM
bermbanger's Avatar
Let me just say this. The smaller in height the rear tire the slower and the taller the faster. If you are saying you want something skinnier and less weight to be faster then you could go with a 22x10x8. Oh by the way ANYTHING fill fit as long as the last number is 8 on the sidewall which matches yours. Maybe that helps.
Old May 30, 2001 | 08:49 PM
QuadDude05's Avatar
so as long as the last number is 8 they will still fit? i thought the smaller the tire (height wise) the more top end? in that case what would i want? what do each number mean? like the first middle n last number?
Old May 31, 2001 | 03:06 PM
YZGUY's Avatar
The first number is the TIRE DIAMETER (HEIGHT); second is the TIRE WIDTH; third is the RIM DIAMETER. If you want to keep the same rims, you must get a ?X?X8 tire. A tire with shorter height (like a 20X11X8) will effectively LOWER your gearing, ie. it will give you more BOTTOM END torque, but at the expense of top end speed (you will lose an inch of ground clearance too!). Conversley a taller tire (like a 22X11X8) will give higher top speed, but will sacrifice low end power.
Bratman2
Aug 6, 2022 01:42 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
rcappie4
Jul 18, 2015 07:51 AM
