HO topend mated to 425 EXPED bottom end??
Old Jun 5, 2001 | 08:29 PM
yamahagye's Avatar
will the top end of an HO engine bolt to the bottom end of the expedition 425 bottom end? you could finally have a manual transmission for you sportsman or scrambler. just wondering. i would be kinda cool if you could get a manual clutch on the 425. just a thought.
laterz
Old Jun 5, 2001 | 10:08 PM
ARMudder's Avatar
[img]i/expressions/face-icon-small-cool.gif[/img]
it would be cool
or just get teh exp 425 engine and put it in the sp 400
Old Jun 6, 2001 | 09:58 AM
425Xpedition's Avatar
The 500 jug and piston will fit. The cam will fit also. The only thing that will not work is the carb. The carb hits the motor mount.
Old Jun 6, 2001 | 01:57 PM
yamahagye's Avatar
there has to be some way to modify the angle of the carb or someting to make the carb fit or go to a different carb altogether. that was a good idea to put the engine in the sportsman 400. heck, why not just put it in the HO 500? i bet it would fit with little or no modifications. the only problem i can see is you would have to hook the engine up to the drive train differently because you power does not go to an auto tranny first. this may present a problem.
Old Jun 6, 2001 | 02:07 PM
ScramblerX's Avatar
Why would somebody want to downgrade to a manual trans? I guess people just are not aware of the unmatched performance of the PVT.
Old Jun 6, 2001 | 06:24 PM
The way the cable goes into the carb is the problem. It is alot different than the setup that is on the bike. You could cut and modify the frame and the gas tank to make it fit. There is a 38mm that will fit on the bike.
A manual transmission is not a downgrade. There are many situations that a belt drive will not stand a chance in the riding that we do. I own both a manual shift and a PVT bike. The type of work or riding makes the choice on what bike I use.
ReconBayou
Oct 31, 2022 05:37 PM
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
