is my 2nd gear taking a dump?
Old Jun 13, 2001 | 07:16 PM
derbyking's Avatar
just got back from the dunes in idaho.third day there i noticed my raptor was making a ratching noise from the chain or gear box,only does it under power in 2nd and feels like the chain is jumping.i adjusted the chain and everthing external looks good.also noticed that my sprocket holder was loose on the axel,you can grab it and move it back and forth,same with the disc brake holder,tighting the axel only cured it for one ride,seems like the splines are wearing out,anyone know if yamaha has a cure for this?by the way i own number 2032. [img]i/expressions/face-icon-small-mad.gif[/img]
Old Jun 14, 2001 | 10:45 AM
NotuRaptor's Avatar
Same problem here. See my post titled "Is this a common rear axle problem on the Raptor". I will send the thread to you via e-mail.
I am also calling the dealer (HondaEast) where I purchased my Raptor to see if I get any further. I bought it in Bear, Delaware so I wouldn't have to pay tax. The dealer I took it to hoping for warranty repair work is in Baltimore, MD. I will let you know how I do.
Old Jun 14, 2001 | 12:09 PM
mtecate4g's Avatar
The reason for the axle splines going to heck is they are not tight from factory. mine was that way when i got mine so i tightened it up. Acouple guys i know listened to the dealer and left it lose. Their splines also have taken a dump. If the dealer doesnt cover the axle and you would like it widerpick up a cheap stock shee axle off of ebay. Can get one for 50-$75. All you need to do is put on some spacers on the outside of the sprocket hub to adjust for the 1/4in offset. Goodluck and i hope i have helped.
Old Jun 14, 2001 | 03:27 PM
derbyking's Avatar
i have a lonestar axel.the sprocket holder fit loose on the stock axel and the lonestar,if i tighten the axel nut the side load will take care of it but after one ride its the same. i know someone else mentioned the chain jumping noise does anyone know if it led to trans problems? thanks
Old Jun 14, 2001 | 04:54 PM
turbine's Avatar
i am thinking of purchasing a raptor i been hearing some junk bout after number 6000 then everything is all godd? is that true and how do i know if im bout to buy a past 6000 model
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
coolguy420
Jul 10, 2015 01:17 AM
black_thunder
Jul 9, 2015 05:58 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
