What is the best gearing for the DS in a 300ft Drag. (Please Help!!!!!!!)
I havn't been on here in a while, but its like nobody drag races on here. I run different set-ups depending on the track. I've been running a 17 tooth front sprocket with my 20" razrs and 22" Realtors. I've lost once this year to a DS with Woods kit. Is it sand or dirt? Tell me more about the conditions and I might able to give some other tips. Like strapping down and so on. What mods do you have and what kind of 20" are you running? Do you have any ETs so I can compare? Later
I Have Ron wood stage 1 kit, I am running 20 inch holeshots.(Or if conditions are right, 18 inch Amrican racer slicks). To lower it I have 400ex shocks up front and i just made the rear shock not as stiff. I thought I needed more low end for 300 feet because I would just reach 5th gear at the finish line. So I am going to try to drop one tooth up front, and see what it does. the conditions are sand, dirt, and dirt that has rubber burned on it so it is like blacktop.
