clutch question
Old Jan 9, 2000 | 12:36 PM
dunner's Avatar
Is there a way to remove the drive & driven pullys with out special tools. The reason for needing to do this is i cant get to the jug nuts on that side so i can touqe them down, rear cover gets in the way. 97,trail boss
Old Jan 9, 2000 | 03:42 PM
quad_man's Avatar
The secondary (rear) clutch will just pull/slide off in most cases. I can't get my primary (front) clutch off wihout the tool.
Old Jan 10, 2000 | 11:20 AM
dunner's Avatar
thanks quad-man, what tools do i need?
Old Jan 10, 2000 | 11:32 AM
myscrambler's Avatar
dunner, you can order the clutch puller part # CLA14012 for $29.50 from AAEN Performance (414) 552-8981, this will remove your primary clutch the secondary clutch comes off by just removing the bolt in the center of the clutch.
Steve Thompson
99 Scrambler 500
Old Jan 10, 2000 | 11:53 AM
Chris Picciotto's Avatar
If you get the clutch off clean the shaft and apply some lube. It will aid in future removal. If it is stuck and won't come off tap the bolt area will a rubber hammer. Usually works for me. The front clutch is a different story and most likely requires a puller.
Chris Picciotto
99 Scrambler 500
Old Jan 10, 2000 | 03:11 PM
dunner's Avatar
thanks everyone for your advice, new to forum this is a great thing. Oh, i have some clutch tools on the way. THANKS!!!!
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
