Stock foam air filter cleaning/oiling tips
Old Jul 4, 2001 | 12:15 AM
Rubidude's Avatar
Just curious as to how everyone cleans and oils their stock foam air filters. Anybody have any good tips or techniques?
Old Jul 4, 2001 | 12:41 AM
AdamPhillips's Avatar
ive always used gas to clean it and have never put oil on it.
Old Jul 4, 2001 | 05:09 AM
ptgb's Avatar
I use mineral spirits, makes for quick work. Rinse it with water. Use a blow dryer (on LOW heat) to dry it out. Spray with foam filter oil. Works great for me.
Old Jul 4, 2001 | 10:12 AM
Need4Speed's Avatar
First off you should always put oil on your filter, ALWAYS. Secondly you shouldn't use a hair dryer on them AT ALL. If you don't use any oil what are the dust particles going to stick to? They go right into your engine. If you use a hair dryer you can damage the glue that holds your filter together and your filter can come apart on you and let unfiltered air in. The way that I do it is I wash the filter in Dawn dishsoap untill it's clean and then rinse it out unill there is no soap left in it. Let it air dry overnight and then I put Maxima FFT Filter Oil on it. After you put the oil on it let the oil set in for about 15-20min and then put it on and go riding.
Old Jul 4, 2001 | 12:28 PM
BigGun's Avatar
I second Need for speeds methods. If you get the oil in a quart and not sprayable, use a big zip lock bag and pour the oil in it, place the filter in it, and work it around thru the filter.
Old Jul 4, 2001 | 06:33 PM
JRM's Avatar
JRM
I remove the oil and major dirt with paint thinner, then I wash with dish soap and water, let dry overnight on top of our A/C vent then re-oil it with sticky foam filter oil so it doesnt drain off the foam, Then I greese the filter sealing edge for a air (dust) tight seal. And always rember to wipe out the air box/ inlet duct and plastic sealing edge on the airbox itself.
PS, just rode my XR and it really ran bad so I took a look at my XR's airbox and found that mice had eaten and packed the entire filter/air duct with nut shells and dog food.
Old Jul 5, 2001 | 12:01 AM
KKKILLER250X's Avatar
What a have been doing is runing filter oil but i am getting really sick of having gooy fingures after i put it back on , so i have found a new way to do this , run NO oil and put a nylon stalking over the filter and double it up and you should be fine . [img]i/expressions/face-icon-small-smile.gif[/img]good times .
Old Jul 8, 2001 | 11:44 PM
kkkiller300ex's Avatar
i put my air filter in a degreeser tub and spray it well and it takes every thing off of it and then get some paper towels and sqweez the rezadew right out of it then grab some oil filter oil and spray down good and put it back together the dgreeser works great but it coast $100 to fill the tank and im not shure how mush the tank coast the degreeser lasts about 6 mounths i like having it.
Old Jul 9, 2001 | 09:40 AM
400excaliber's Avatar
I wash the filter out with mineral spirits, then soap and water...and let it dry. (which takes quite awhile.) Then spray with foam filter oil, inside and out, and squish it all around to ensure the entire filter has been coated. I also try and get the excess oil off which is really messy too. But I figure the engine is worth a little dedicated TLC!
Stever6368
Aug 16, 2015 07:34 PM
cSchwartz
Jul 12, 2015 07:42 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:43 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
