Off-Topic:Need Help rebuilding Z50R
Old Jul 4, 2001 | 08:42 PM
Hondapride's Avatar
I am rebuilding my little brothers 1980 Honda Z50R.
I have all the parts and a new gasket kit.
I took off the cylinder head and cleaned the combustion chamber. If I soak the entire head in parts cleaner, is there still a need for me to take out the cam and rocker arms?
Old Jul 5, 2001 | 12:07 AM
Need4Speed's Avatar
I would just to be on the safe side. It's not like you'll hurt anything cleaning it out. Just make sure you oil it up good when you put everything back together. Let me know how she turns out!
Old Jul 5, 2001 | 06:15 AM
JRM's Avatar
JRM
wow, never seen a Z50 engine wear out! My nebor has had one since he was 5 and he has blown up every other bike he has had since such as a ATC200M(shatterd pistion), XR80(upper rod), XR250(valve float=broken pistion), CR80R (seezed from improper mix), but the Z50 still runs first kick without any smoke and has never had a oil change!
Old Jul 5, 2001 | 07:56 AM
lumpdog's Avatar
Since we're going to go down this road, anybody have a good source in the US for Takegawa or Kitaco hop-ups for the honda z50? Any help pointing me in the right direction would be greatly appreciated.
thanks
lump-dog
Old Jul 5, 2001 | 08:53 AM
HP500EFI's Avatar
Nice topic,
I am in need of a new exhaust system for my sons 1985 Z50. Does anybody have any information on where I can get one. The muffler is shot. It has rusted over the years and the rust is now breaking off the inside of the muffler and it has gotten so bad that it has clogged the muffler so that no air can pass through.
I have tried cleaning it and it runs for about 5 minutes. Honestly, I have not even checked with my dealer to see if a new OEM muffler is available.
Old Jul 5, 2001 | 11:50 AM
bermbanger's Avatar
Big Gun makes a header and silencer for the Z50. Parts cleaner doesn't cut it. Take it apart and inspect for damage.
Old Jul 5, 2001 | 09:25 PM
Hondapride's Avatar
Wow thanks for all the help!
The motor is not worn out, it still runs but it is using a whole lot of oil and blowing a whole lot of smoke.
I took off the cylinder today and it needs new rings badly.
The cylinder walls look fine, and the piston itself is ok too.
I was going to clean out the cylinder but then I remembered hearing somewhere that you can't clean the carbon ring around the top of the cylinder bore, or your engine will use a lot of oil. Is this true?
Also what is the best way to break in the motor once I have the new rings installed?
Old Jul 6, 2001 | 02:30 AM
JRM's Avatar
JRM
If there is a ridge worn below the carbon edge, have it bored one oversize. If there is no ridge, go ahead and hone and re-ring it makeing sure the oil ring ends are oppesite of each other[img]i/expressions/face-icon-small-smile.gif[/img] Rember the valve seals and just ride it light without overreving it for a while to break it in.
Old Jul 8, 2001 | 12:27 AM
Hondapride's Avatar
well it took me about 6/h today to clean out the cylinder head, adjust the valves, put new piston rings on and give it a little paint job.
It has way more compression and it starts first kick.
I am really glad that I did it because it runs much better now.
Thanks for all the help
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
